Tacacs for 7600 with MWAM module
I have configured the MWAM processors to support tacacs aaa when logging in via telnet to them I have it functional when telnetting to a defined mgmt ddress in the MWAM, but when using the 'session' command from the supervisor, 'Authorization failed' is shown. I would like to have 'session' access to the MWAM card without tacacs since that will be enabled on the 7600 also. So now I can't access the MWAM card from the supervisor. Please advise.
regards,
//Fredrik
1 REPLY
Bronze
Re: Tacacs for 7600 with MWAM module
As far as I know, it's not possible. In any emergency cases, if you want to connect to the module without AAA authentication, you can give "reset 4" which resets the MWAM module and requires no authentication then after. But you will loose the configuration.
198
