Tacacs login by CW2000 to 2512 does not work
For some reason our CW2000 5th edition has problems logging into 2512 routers when Tacacs is on.
I get this debug info with debug telnet
.Jul 17 09:24:47.216: Telnet19: 1 1 251 1
.Jul 17 09:24:47.220: TCP19: Telnet sent WILL ECHO (1)
.Jul 17 09:24:47.220: Telnet19: 2 2 251 3
.Jul 17 09:24:47.224: TCP19: Telnet sent WILL SUPPRESS-GA (3)
.Jul 17 09:24:47.224: Telnet19: 80000 80000 253 24
.Jul 17 09:24:47.228: TCP19: Telnet sent DO TTY-TYPE (24)
.Jul 17 09:24:47.228: Telnet19: 10000000 10000000 253 31
.Jul 17 09:24:47.232: TCP19: Telnet sent DO WINDOW-SIZE (31)
.Jul 17 09:24:47.236: comport option isn't valid on line type 3
.Jul 17 09:24:47.577: Telnet20: 1 1 251 1
.Jul 17 09:24:47.577: TCP20: Telnet sent WILL ECHO (1)
.Jul 17 09:24:47.581: Telnet20: 2 2 251 3
.Jul 17 09:24:47.581: TCP20: Telnet sent WILL SUPPRESS-GA (3)
.Jul 17 09:24:47.585: Telnet20: 80000 80000 253 24
.Jul 17 09:24:47.589: TCP20: Telnet sent DO TTY-TYPE (24)
.Jul 17 09:24:47.589: Telnet20: 10000000 10000000 253 31
.Jul 17 09:24:47.593: TCP20: Telnet sent DO WINDOW-SIZE (31)
.Jul 17 09:24:47.593: comport option isn't valid on line type 3
1 REPLY
Bronze
Re: Tacacs login by CW2000 to 2512 does not work
There are few issues related to CW2000 and telnet. If you have access to Bug toolkit, see if CSCdm44821 or CSCdj33943 are applicable to you.
87
