TCP/IP and layer two payload
Is it possible to use TCP/IP header compression and layer two payload compression simultaneously?
TIA
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Re: TCP/IP and layer two payload
No, I would not recommend using these two compressions together. Typically the link will not come up or pass IP traffic. If I had to choose between the two I’d use layer two payload compression.
1 REPLY
113
