I don't think the 3640 has such a feature by itself, do you have a switch attached to the router ? If so, you could use the Server Load Balancing IOS feature. If you haven't looked into that yet, check out this link:
http://www.cisco.com/en/US/partner/products/hw/switches/ps672/products_configuration_guide_chapter09186a008007f253.html#wp1110581
With this feature, you can define a virtual server which represents a group of real servers in a cluster of network servers known as a server farm. In this environment a client connects to the IP address of the virtual server. When a client initiates a connection to the virtual server, the SLB function chooses a real server for the connection, based on a configured load-balancing algorithm.
HTH,
GP
