telnet connection error
I am getting the following error on a 4908l3-G switch when trying to telnet to the IP address. "Password required, but not set".
I can console into the unit what am I looking to change to stop this from happening.
  • Other Network Infrastructure Subjects
1 REPLY
Re: telnet connection error
That is the default behavior of all IOS based platforms. Using console session, set a password and you should be able to telnet. Set passwords under line vty 0 4 and also an enable password. The following page should help as well
http://cio.cisco.com/univercd/cc/td/doc/product/l3sw/4908g_l3/ios_12/18w522a/config/init_cfg.htm#xtocid6
For example, if you want cisco to be the password, do the following
config terminal
enable password cisco
line vty 0 4
password cisco
end
wr mem
252
