09-24-2002 07:13 AM - edited 03-02-2019 01:35 AM
I need to create a menu system to run various basic admin commands on an AS5300. I need to do this without altering the normal telnet in vty access though. Ive got two plans to do this.
1) use the highest number vty to run a menu system, allowing people to telnet into that specifically. Now people should be able to telnet in by adding the line number to 2000 as far as i can see, but as of yet Ive had no success with it. I can reverse telnet to the aux port but not the vtys. Does anyone have any ideas?
The second problem with that is that if the AS5300 is upgraded with more lines, the line numbers of the vtys will change, and therefore so will the ip port numbers which wouldn't be good. Is there a way of running a vty on a specific IP port?
2) My other idea was to use the protocol translation feature to spawn off a vty. Im thinking either
translate tcp <myrouter> port <myspecificport> autocommand menu <mymenu>
that sucks as theres no password, so maybe
translate tcp <myrouter> port <myspecificport> virtual-template <mytemplate>
and create a vty template in the same fashion as above. I dont know if either of these will work yet though, and lets face it - using protocol translation to bring up a menu would be a monumentally hideous hack if it did work.
At the moment Im pursuing idea 1. I have a 2503 that im trying things out on, vty 4 is line 6 and is configured as
line vty 4
login
password mypassword
autocommand menu mymenu
When I try
telnet myrouter 2006
I get no connection, yet I can do
telnet myrouter 2001
to connect to the aux port.
Help!
Lauren
09-24-2002 10:55 AM
You can't reverse telnet to virtual VTY ports.
Your best and easiest approach is to define an autocommand with a generic ADMIN username; something like:
username ADMIN autocommand MENU
username ADMIN password cisco
ADMIN users which connect to the cisco will automatically get the menu; other users (who have password priviledges) that connect to the cisco will get the regular prompt. You could also do this via AAA, if you are using an external AAA server.
09-24-2002 04:40 PM
TO add to above, VTY line assignment is decided by the router, we cannot decide which line number is assigned.
