Telnet password problems
Apologies for such a basic problem, but just coming back into Cisco after some time away and am very rusty.
Have programmed a 2611 via the console, but am attempting to access it via telnet. It is asking me for a username, which I did not program. I need to know if there is a default username that I assume goes with the user mode password (ie level 0 or cisco or something) and what is the command I need to put into the line config to remove the need for a username? I want to be able to telnet in and just be prompted for a password as per normal.
Dean
Bronze
Re: Telnet password problems
There is no default username.
Check the config at line vty 0 4. If there's a 'login local' command, disable it.
No there is no login command in the vty line config at all, just a password. normally I would expect to see "login" on its own but there's nothing.
to set up a simple telnet, type ( from conf terminal mode):
line vty 0 4
password XXXXXX
login
CTRL-z out of config and that should be all you need
cheers
Do you have aaa authentication configured??
if not try the following ...
router(config)#aaa new-model
router(config)#aaa authentication login no_tacacs local
router(config)#username password
router(config-line)#login authentication no_tacacs
then you would use the username and password you configure ... Hope this helps.
114
