Silver
Telnetting using another address
I know that using an extended ping, one can specify the source address the router should use for the ping. What I want to know is, if it is possible to telnet to another router and specify the source address that the router should use for the connection.
Silver
Re: Telnetting using another address
Yes, you can use:
ip telnet source
Source address would now be the address of interface specified.
Thanks.
Or,
use Router#telnet /source-interface
will do the job.
Silver
Thanks for the info, quite usefull. But imagine the following scenario where the interface has secondary address. And you want the telnet to source with the secondary address, is that possible.
94
