temperature air inlet / outlet
Hello, in order to ensure a device is not overheating, is it better to monitor the switches 'air inlet' or 'air outlet' temperature ?
Or does it not matter i.e. either one is fine.
Thanks kindly.
1 ACCEPTED SOLUTION
Super Bronze
I would think monitoring
I would think monitoring whatever the system reports for its system temperature is what you want to do.  More likely that somewhere measures internal device temperature.
Super Bronze
VIP Super Bronze
Each device has multiple hardware sensors, and so they can be monitored by whatever software you will use to manage your devices. If the system gets too hot, it will alert you.
28
