Webcast-Catalyst9k
Temporary Router on a Stick for Inter-VLAN Routing
All,
I need to setup Inter-VLAN Routing on my network, as we are about to migrate to a new IP address range, due to an IP address shortage. For varous logistical reasons I will not recieve my 6500 Supervisor II + MSFC Modules for quite some time. My question is can I use a low end 2600 series router like the 2610XM as a router on a stick, using ISL on the integrated 10/100 port. If not what is the cost effective router to purchase as a temporary solution, until the SupII modules are purchased and commisioned.
Regards & thanks to all,
Mike O'Sullivan
Re: Temporary Router on a Stick for Inter-VLAN Routing
The following page on CCO should help
http://www.cisco.com/warp/public/473/#Trunking
The 2610xm can't do the job the first cisco who does is de 2620.
91
