Terminal Monitor command does not work anymore
We are running 2 AS5200 with 11.3 IOS Versions running. On both boxes the "Term Moni" does not Work.
So we decided to upgrade one Box, after that the command works for some time on this Box.
After some time the command stops working again.
Any ideas
Werner
1 REPLY
Silver
Re: Terminal Monitor command does not work anymore
This command was introduced in version 10.0. It should work with 11.3 also. Check if there is some other problem.
495
