Terminating a single data call on a PRI
Is there a command that will terminate a call that is active on a PRI?. For example dialer 29 may be bound to an individual PRI channel becuase it is active and I would like to terminate it without bringing down any other active calls.
I am aware of "isdn disconnect" introduced in 12.0(3)T but I think this is only for BRI's and I am only running 12.0(23) anyway
Thanks in advance.
1 ACCEPTED SOLUTION
Re: Terminating a single data call on a PRI
YES..You can findout the channel/interface on which that user you want to disconnect using " sh users"
Once you have that interface on which that user is connected, you can use "clear interface " command to clear that user.
Thanks very much for the info.
105
