Community Member
test pas eeprom command failed!
I have a cisco 2621 router with a wic-t.I used followed command:
router#sh ver
cisco 2621 (MPC860) processor (revision 0x101) with 27648K/5120K bytes of memory
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Router#test pas eeprom ?
<cr>
Use NMC93C46 ID EEPROM [y]:
Port Adaptor [0]:
Port 0 eeprom (? for help)[?]: d //dump eeprom contents
%Read access failed
Why is this?
Thanks.
Bronze
Re: test pas eeprom command failed!
I have tried this command on my box and I get a similar output. Looks like it is some undocumented command used by Cisco folks. What for your trying this command exactly?
Community Member
Hello:
So,my router show a error "slot 0 eeprom failed" when system boot,and i search some info on cisco site,i finded a command "test aim eeprom",then i try this command,but no this command,and i find a command "test pas eeprom",try it but ....:(
Why,this ?
What can i do?
Thanks.
152
