tftp via console cable
Hi all, is it possible for me to tftp my running config into my router using the console port ?
Re: tftp via console cable
Its not possible for TFTP as its a network layer and above application.To download running-config to router you need utility called xmodem.
(1)Connect the console and access the router through HyperTerminal
(2)Give the command
Router#copy xmodem: running-config
(3)Start the xmodem transfer using Transfer-->send File . There select the file "running-config" in ur PC and select protocol as "xmodem".
This will transfer the "running-config" from PC to "running-config" to router.
Pls rate all posts
JD
Silver
You can use
copy tftp running-config - but it will merge the current running-config with the new.
It copies the file from tftp server to the router.
bye
FCS
Please rate me if I helped.
hey guys,
I may be sidestepping the issue a bit, but if you are in Rommon mode on the router and you need a faster IOS download than xmodem try this.
rommon 16 > IP_ADDRESS=171.68.171.0
rommon 17 > IP_SUBNET_MASK=255.255.254.0
rommon 18 > DEFAULT_GATEWAY=171.68.170.3
rommon 19 > TFTP_SERVER=171.69.1.129
rommon 20 > TFTP_FILE=c2600-is-mz.113-2.0.3.Q
rommon 21 > tftpdnld
Have you TFTP server open and your host connect to a local lan port & voila, you get TFTP Image transfer speed.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
15360
