Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
The Connect from Intel Pro/1000 T to 1000base-t Port on Catalyst 4000 (WS-X4412-2GB-T= module) Not Working Properly
The connect from Intel Pro/1000 T to 1000base-t port on Catalyst 4000 (WS-X4412-2GB-T= module) is not working properly. The Intel Pro/1000 T NIC connects to a 10/100 OK. Auto-negotiation is set at both ends. We can successfully ping across the link. However performance is so poor as to make the connection unusable.
1 REPLY
Anonymous
N/A
Re: The Connect from Intel Pro/1000 T to 1000base-t Port on Cata
When an Intel Pro/1000 T NIC is connected to a Catalyst switch, the customer may see poor network connections or excessive numbers of dropped packets. The problem arises when a module with a TBI interface transmits an odd byte packet to a receiver with a Gigabit Media Independent Interface (GMII).
The interoperability issue is a result of the implementation of Carrier Extension. Carrier Extension is detailed in sub section 35.2.3.5 in the IEEE 802.3 specification. Carrier Extension can be used to pad the last byte of a packet, so the packet is aligned on an even numbered boundary.
91
