Webcast-Catalyst9k
The replacement of X.25 with TCP/IP for Ericsson OSS (Mobile Switching)
I wonder if any of you've ever come across the integration of the Ericsson OSS with Cisco Router. Currently we are attempting to interface the Ericsson OSS Server with Cisco 3600 Router. It is to connect the Ericsson OSS Server's Ethernet port to a Cisco 3662's Fast Ethernet Port. Two IP addresses have been assigned to both interfaces and the IP connection is up (Ping - Live). However the application is sending X.25 traffic, Ericsson claimed it was XOE (X.25 over Ethernet). Hence each time the server attempts to establish a connection to a remote Switch Equipment on the other end of the Cisco data network it causes the Cisco Router to reboot or crash. The Cisco Router can't do XOE but XOT. Any idea? If you guys have implemented it before, care to share the knowledge.
Any suggestion will be appreciated. Thanks.
1 REPLY
Re: The replacement of X.25 with TCP/IP for Ericsson OSS (Mobile
Allrite. We've been trying for nearly two months. The result so far tells us that Cisco Router is not compatible cuz it is still crashing. I guess we would probably have to stop here. Thanks.
333
