Community Member
there is a question in our campus network . help !!
we created some sub-interface on the 7500 serier router. after a running time , there is a problem in vlans. example
interface FastEthernet4/0/0.3
encapsulation dot1Q 20
ip address 10.1.19.9 255.255.255.248
no ip redirects
no ip proxy-arp
ip nat inside
no ip mroute-cache
at the vlan 20 , from 10.1.19.10 ping 10.1.9.9 is not connect. if renew vlan 20 vlan 21 , the problem is the solved.
1 REPLY
Community Member
Re: there is a question in our campus network . help !!
I really don't understatnd "if renew vlan 20 vlan 21 , the problem is the solved".
If you mean that you have changed the dot1q encapsulation to vlan21, then the problem is with your assignment to the Vlans or trunks on whatever switch port, if you mean that you pinged from the Vlan to other, then make sure that the subnets are assigned correctly to the Vlans since the subnet used for the router interface is /29.
good luck
81
