Community Member
Token Ring Interface
Hello All,
I'm having a bit of troubles configuring a Token Ring Interface. I know TO is no longer supported or used.
I have a 2504 Router with 1 TO interface.
I have purchased a RJ45/DB9M modular Adapter for the TO.
How do I set the TO interface to use a standard RJ45 ethernet cable?
Can this be done?
Thanks in Advance.
juan
1 REPLY
Gold
Re: Token Ring Interface
RJ-45 to DB-9 Configuration
Connect the pins on the RJ-45 connector to the pins on the DB-9 connector as follows:
RJ-45 Pin
Wire Color
DB-9 Pin
Signal
Black (or Light Orange)
RCV+
Red (or Light Green)
XMIT-
Green (or Solid Green)
6
RCV-
6
Yellow (or Solid Orange)
9
XMIT+
Table 11 RJ-45 to DB-9 Configuration
The above configuration can be used whether the DB-9 connector is male or female, because the cables are “straight-through” with no cross-overs as found in a null modem.
101
