Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Token ring vlan v.s. Subnet
In a ethernet vlan, usually on vlan is mapped to one ip subnet. In token ring vlan enviroment, is there any mapping among TrBRF vlan, TrCRF vlan, and ip subnet?
Thanks for you help.
Fujin
Re: Token ring vlan v.s. Subnet
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
For token ring vlans a TrBRF vlan would be the parent of the child CRF's as a layer2 vlan. So for a IP subnet basically a 1 to 1 relation CAN exist for TrBRF's and there child CRF vlans.
So you can configure a subnet on a router with a BRF vlan and for all the child CRF vlans, they would be all part of the same subnet that the BRF lives in.
249
