Webcast-Catalyst9k
Tokenring ring number hex or decimal?
I checked the cisco document, the tokenring switch 3900/3920 uses hexdecimal as the ring number, while the router tokering interface, it use demimal ring number, is there any in-consistancy? don't I need to convert them when doing configuration?
Thanks a lot.
Fujin
1 REPLY
Re: Tokenring ring number hex or decimal?
You can configure the ring number on the router with
a 0x in front
105
