too long configuration in 1603
I have 15 dialers in Cisco 1603 for different ISDN connections, I increment "boot buffersize" and I'll be able to add next dialer, but after rebooting router - added dialer disapear. How I can increase configuration file?
Re: too long configuration in 1603
Have you saved the running configuration to the NVRAM.?
Normally nvram would be having enough memory to hold the configuration.
-Deepu
yes, of course, I have saved configuration. I,m sorry I have to precise "disapear dialer", I'm not losing new dialer config, but last config lines, like last access-list, line con, line vty.
The NVRAM that stores your config is about 7K in size. This should be adequate, even for your config. It looks like you have a DRAM issue. How much memory is there in your 1603? Is it ia 1603 or a 1603R? The problem can also be IOS-version related. Need more info to check this.
Posting a -sh ver- would supply the required info.
Leo
this is a sh ver:
IOS (tm) 1600 Software (C1600-Y-M), Version 11.3(10)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 01-Jun-99 19:00 by pwade
Image text-base: 0x02005000, data-base: 0x023DBE84
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
router uptime is 5 weeks, 5 days, 3 hours, 37 minutes
System restarted by power-on
System image file is "c1600-y-mz.113-10.T", booted via flash
cisco 1603 (68360) processor (revision C) with 6144K/2048K bytes of memory.
Processor board ID 17075392, with hardware revision 00000002
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
System/IO memory with parity disabled
8192K bytes of DRAM onboard
System running from RAM
8K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
Before doing any further checks on the config etc. , I would advise you to upgrade to a more recent IOS. 11.3-10, T-release is not a suitable environment to test whatever issue on.
I even think there may have been known issues with this release related to your problem. Please upgrade to v12.0 and use the GD software. 12.0(24) or (25) I suspect that this will solve the problem.
Leo
243
