Webcast-Catalyst9k
s.m
too many collisions on my FE interface running a BGP session
Greetings......
I am running a BGP session with a carrier network and have terminated its link on my FE 0/1 3660 router.
For my location whatever bandwidth i am having is thru this link .
I am seeing a lot of COLLISIONs on that interface.
the "counter for collision" rises to abt 1500 in abt a day`s time.
Is this normal or due to some prob with the media or something else.
Appreciation in advance to the replyer.....
Re: too many collisions on my FE interface running a BGP session
Since you're seeing collisions, you have the interface set to half-duplex. Are you seeing any late collisions? If so, you have a duplex mismatch, most likely.
Can you go to full duplex? That would eliminate the collisions you're seeing.
Mick.
s.m
Dear mickey.....
I had just posted a query for the collisions i had been getting on my FE.
first of all thanks a lot for being so quick to reply to and secondly u were rite that it was half duplex.
But the thing is i am changing it to Full-Duplex but it isnt changing.
After i give the command "Full-Duplex"......and see the interface...it still shows me "Half-Duplex"
Just take a look......should i decrease the DLY also
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:04, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:07:24
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 46000 bits/sec, 16 packets/sec
5 minute output rate 10000 bits/sec, 14 packets/sec
8276 packets input, 2821028 bytes
Received 98 broadcasts, 0 runts, 0 giants, 0 throttles
20 input errors, 20 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast
6900 packets output, 658877 bytes, 0 underruns
0 lost carrier, 0 no carrier
according to your SH INT, you may be using a FE port, but it is seeing only 10/half. This would imply that your provider is only supplying a 10/half connection to you.
Expect collisions. 1500 per day is nothing. Figure that if collisions exceed 10% of your PPS, you have the *beginnings* of a problem with collisions.
Mick.
s.m
Thanks again......
Do u mean my Carrier provider is giving me 10/half.
As i am myself a provider...
Is it that the Full or Half duplex operations have to be enabled on both WAN ends .What i mean is , since my carrier has not config a full duplex operation , is it why i am not able to change it myself to Full-Duplex.
302
