Tool for Traffic/Link Monitoring.
Does Cisco have any Traffic/Link monitoring tools......which can be downloaded from a CCO login.
Actually i wana monitor my WIC-2T (Smart Serial Link)........CWW 6.0 doesnt give an exhaustive Traffic display.
Thanx in advance,
regards,
Vijayendra K. Sharma
Re: Tool for Traffic/Link Monitoring.
The only app I can think of in that case you aren't satisfied with CWW is the
QoS Device Manager. You need to enable NBAR and some more commands, it also works only on a small part of hw.
Otherwise you must take a look at the shareware tools.
MRTG and all of the lookalikes which are out there !
Regards Jorgen
awo
When i reading those forum section i always can see a lot of questions about funcionality of MRTG but in any of Cisco products. It is trully any way to do that is to run MRTG or ovgraph from OV NNM ? So the main feature that customers need isn't suported in "in box" way in CW2k products ?
RTM (part of both LMS and RWAN) will do the job. IPM from RWAN is also an option depending on your needs.
Blue
RTM can do this, but it's not a free ware download from CCO. Try MRTG.
MRTG Is amazing.............its beautiful.
Thank you all of you for proper guidance.
reagards,
Vijayendra K. Sharma.
227
