Community Member
Tracing a frame thru switches in a flat network
Is there a way to track/ trace/ audit what specific switches that a frame traverses from source to destination in a flat network??..this would be functionality similar to traceroute for IP...
thx
Re: Tracing a frame thru switches in a flat network
What switches do you have? Take a look at the l2trace command in CAT OS
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_6_3/cmd_ref/ghi_cmd.htm#96626
Community Member
I have a 4006 and some 3500XL switches and some 2950's. Also some BR350 wireless boxes on the network.
I tried using the 12trace command on my 4006, but it gave me the "unrecognized command" error...
Catalyst 4000 family switches must be running supervisor engine software release 6.2 or later. If you are not,I suggest that you upgrade to 6.3(9). Here is the output from a labswitch
Console> (enable) l2trace
Usage: l2trace [vlan] [detail]
l2trace [detail]
(src-ip-addr, dest-ip-addr: IP alias or IP address)
Console> (enable)
120
