Traffic leaking between PVLAN Isolated ports
Is it possible to leak traffic between ports configured as 'PVLAN isolated' ?
Task is pretty simple - there is an IP segment, terminated on cat3750 SVI, and two test servers connected to this switch in ports, configurated for isolated PVLAN. I'd like to be sure there is no uncontrolled communication between those servers, except permitted traffic.
Both servers can reach SVI IP address, but cant reach each other. So far, so good, PVLAN works. What about allowing some traffic between those hosts? Any ideas if thats possible at all, and how to configure devices?
Re: Traffic leaking between PVLAN Isolated ports
you could place the two servers in two different VLANs, let the Cat 3750 route between them and apply access-lists to control the desired traffic.
Have a look at
"Configuring Network Security with ACLs"
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a0080403fec.html#
for all possibilities.
Hope this helps
Martin
All servers are placed in one VLAN (IP subnet) and it's supposed to stay that way. Test is about PVLAN usage.
Anyone else ?
Use local proxy arp on SVI interface (ip local-proxy-arp). Then you can apply RACL to limit traffic between servers for specific applications.
Bostjan
138
