Webcast-Catalyst9k
Traffic Management with a VLAN
I have two different L3 Switches (4006 and 4003) connected via trunk.
Assumeing one PC is connected to each switch.
Now I would like to control TCP, UDP, ICMP traffic between these two PCs which are under same VLAN.
Please suggest a solution/recommendation to achieve the above requested security requirement.
Seshu
1 REPLY
Silver
Re: Traffic Management with a VLAN
Seshu,
For L2 policing you can use a port based or agregate policer for an entire VLAN. Check out this link for more information on this:
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_tech_note09186a00800946e9.shtml
Hope this helps you,
Don
210
