Traffic shaping on a port level
How can I send traffic thats inbound on the LAN side to a specific PVC on the Frame Relay WAN side? Specificly ftp control traffic. I want the ftp control port traffic to use only one PVC while all other traffic is equal cost load balanced across both PVC's with EIGRP.
  • Other Network Infrastructure Subjects
1 REPLY
Re: Traffic shaping on a port level
You can use policy routing... which is source based routing.
You can force traffic from a certain source subnet (including ports) matching any destination (including ports) to go out any direction you want.
I recommend using policy routing as a temporary fix until you can find a permanent solution. Try to manipulate normal routing first before resorting to policy routing.
109
