Community Member
Traffic shaping on FR connection, 140ms packet delay? normal?
How much delay should I expect when using traffic shaping on a Frame Relay connection, FIFO queuing?
This is a 3640, IP only, 12.2(5a) 32MB dram. The router is not busy.
The connection is a simple serial connection, 1,280Kbps to a DCE device, Cisco IAD interface emulating FR. Testing showed a ping between the 3640 and the IAD DCE(not going over the Wan) takes 2-3ms without Traffic shaping but 140+ms with traffic shaping. The serial port is not very busy with 4 other sites, and monitoring TS (show Traffic Stat) showed it not active at the time of testing.
The remote sites and out testing shows a dramatic increase in delay when we increase the packet size from 100 to 1,000 Bytes.
The router was power cycled and the results did not change.
Is a 140ms delay normal with traffic shaping?
Should I deploy a different queuing methond? (now default method FIFO)
Is there known bugs at this level? (I could not find any hits on this)
Re: Traffic shaping on FR connection, 140ms packet delay? normal
Hi - the delay with FRTS is going to be more than without FRTS. However, there are a couple of things to look at:
- what is the configured Bc on the map class
- do you see the pkts delayed / bytes delayed counter incrementing in sh frame pvc xx
The queuing method should be fine - also take a look at the link below for more info on FRTS:
Community Member
Here is relative config info for the line, PVC and map class used.
interface Serial0/1
description CID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
bandwidth 1280
no ip address
no ip proxy-arp
encapsulation frame-relay
load-interval 30
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/1.100 point-to-point
description xxx diag access
ip address
frame-relay class 256Kcir
frame-relay interface-dlci 100 IETF
map-class frame-relay 256Kcir
no frame-relay adaptive-shaping
frame-relay cir 256000
frame-relay mincir 256000
When we were testing the traffic shaping stats and PVC stats did not show packets delayed. The circuit s0/1 was around 100k total usage on a 30 second avg.
When using a ping length of 100 the avg delay was 2ms.
When using a ping length of 1,000 the avg delay was 140ms.
I found that when I used a map class with a "mincir=192000" and put the frame class statement on the line S0/1 the delay for a 1,000 byte ping was reduced to 35ms or so. I believe this is related to the total number of PVC on the line had a mincir that >= total line speed.
When I removed the "Frame traffic-shaping" statement from the line S0/1 the respone of a 1,000 byte ping averaged 16ms, or so.
The carrier want us to use traffic shaping, to avoid FR to ATM overload but we find, for now it works without TS. They may insist that we use TS as the traffic increases.
Your opinion please.
