Traffic Shaping Problem
IOS 12.2(13)T3
When I enable traffic shaping 1 PVC (out of 37 total) experiences substantial drops and increase in latency.
Here's the relevant config:
ip cef
interface Hssi1/0
encapsulation frame-relay
no ip mroute-cache
serial restart_delay 0
cdp enable
frame-relay traffic-shaping
frame-relay lmi-type cisco
frame-relay ip rtp header-compression passive
interface Hssi1/0.27 point-to-point
ip address (omitted) 255.255.255.252
ip mtu 1500
ip ospf network point-to-multipoint
ip ospf cost 150
frame-relay interface-dlci 102
class FRCLASS_512
map-class frame-relay FRCLASS_512
frame-relay cir 512000
frame-relay bc 5120
frame-relay be 0
frame-relay mincir 512000
I tried reducing the CIR to 384 and 128 - just in case the provider info was incorrect, but it didn't help.
Other possibly relevant info: One of the PVCs is carrying voice so I have a policy built, and I am also using RTP Header compression on the HSSI interface.
Any help would be greatly appreciated.
Re: Traffic Shaping Problem
It's the MinCIR you need to reduce not the CIR. CIR is the access rate.
They were both reduced.
Doesn't matter though - I worked out the solution with TAC today. It turns out the service provider was not policing their individual PVCs, so the overall throughput per PVC was much higher prior to traffic shaping. When I enabled traffic-shaping it forced the PVCs to abide by the CIR and high utilization links were suffering loss. The solution was to configure a CIR for the PVCs to the interface speed (to 44mbs, essentially wide open), set the mincir to the provider CIR (128k, 512k, depending on the PVC), and enable adaptive shaping becn. Worked like a charm...
113
