Trafic-shape and network management
How can I read, with snmp, the value of the variable shaping return by the command sh traffic-shape statistics ?
example :
esnrmtn1>sh traf st
Access Queue Packets Bytes Packets Bytes Shaping
I/F List Depth Delayed Delayed Active
Fa0/0 120 0 127944 18732611 5761 4637875 no
Fa0/0 160 0 49053 17851824 10355 9111266 no
esnrmtn1>
Thanks in advance
Bronze
Re: Trafic-shape and network management
To read a value from the router, first you must enable SNMP on the router. This will allow the router to respond to the queries from the Network Management Station, such as Cisco Works. See the following link to configure router for SNMP:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_c/fcfprt3/fcf014.htm
Once your router is configured forSNMP, your Network Management Station can query for any SNMP object on the router and get the values. You must look for the "shaping Active" in the NMS and query the router. Not sure how to do this. I guess, it will be different for different NMS.
Thanks for your answer.
I have done all snmp definition and i am reading a lot of varaibale but i dont found the specific one for the traffic-shape. Could you please help me to find
the right mib.
Thanks in advance Gilles
Go to http://www.mibdepot.com and use the search utility...
Type in "traffic shaping" and clear all choices less Cisco and IETF RFCs...This will give you a list you can go thru and select the items you want...
On the left hand side of the search results is a "Viewing Mode" and I usually use TEXT since that will provide the whole mib...
If you are not comfortable on reading mibs you can read off the FAQs or check out CIsco's SNMP overview:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/dialsol/nmssol/snmpover.htm
Hope that helps..
Jim
135
