10-24-2003 04:48 AM - edited 03-02-2019 11:14 AM
I am setting up a router and keep getting this message,
00:15:23: %PQUICC-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
HOw do I stop it
10-24-2003 05:09 AM
You don't mention what router you are trying to work with.
If you are using a router that uses an external transceiver for the Ethernet connection, then make sure the transceiver has the setting for "SQE" turned off (it's also called "heartbeat").
If your router does not use an external transceiver, then chances are your cable is bad (bad crimp, improper pair ordering, broken/crushed/stretched).
Try plugging in the other end into a different port or switch and see if the error changes or goes away: the problem can be on the other end.
Good Luck
Scott
08-22-2021 08:49 PM
А как отключить SQE?
09-06-2013 05:54 AM
Hi Scott,
I think the problem is the cable! The following pin-out is required:
1 ----- 1
2 ----- 2
3 ----- 6
4 ----- 5
5 ----- 4
6 ----- 3
7 ----- 7
8 ----- 8
We used this and the fault has disappeared!!
Mario
09-06-2013 06:05 AM
Just to let you know, you are responding to a 10 years old posting.
