Transparent Bridging over X.25 and BVI Interface (IRB)
Hi together,
we have a problem with an IRB Configuration via an X.25 Network.
I shortly explain what we have done:
We have 2 Routers (Router A and Router B) connected via X.25 pt-2-pt Subinterfaces. At Router B we have the IRB Feature activated and we have configured an BVI interface that is linked to the X.25 Subinterface. At Router A we have connected an PC to the LAN Interface and the Router should only bridge (IP Traffic) incomming packets from the LAN Interface (fe0/0.55). to the outgoing serial interface (s0/0.55).
The PC (mac 0010.5afb.36cb ) that is connected on e0/0 at Router A has the remote IP Address (192.168.90.33) from the BVI 1 Interface on Router B.
This sounds a little bit crazy but we need this scenario for Management reasons.
With this X.25 encapsulation it is not working (Try to ping from the PC to the BVI Interface). But if we change the encapsulation of serial leased Lines to ppp or Cisco HDLC than it works fine.
Here are extracts from the X25. configs:
Router A:
interface FastEthernet0/0
no ip address
bridge-group 55
bridge-group 55 spanning-disabled
interface Serial0/0
bandwidth 512
no ip address
encapsulation x25
no ip route-cache
no ip mroute-cache
x25 address 67890
x25 htc 100
x25 win 7
x25 wout 7
x25 nvc 8
no cdp enable
lapb N1 2104
interface Serial0/0.55 point-to-point
no ip route-cache
x25 map bridge 12345 broadcast
bridge-group 55
bridge 55 protocol ieee
bridge 55 route ip
Router B:
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface BVI1
ip address 192.168.90.34 255.255.255.252
interface Serial0
no ip address
encapsulation x25 dce
no ip route-cache
no ip mroute-cache
bandwidth 512
x25 address 12345
x25 htc 100
x25 win 7
x25 wout 7
clockrate 250000
no cdp enable
lapb N1 2104
interface Serial0.1 point-to-point
no ip route-cache
x25 map bridge 67890 broadcast
bridge-group 1
bridge-group 1 spanning-disabled
The X.25 vc is up and running. We also see that the packets are bridged over the Link. See output of "sh bridge" command.
Router-B#sh bridge
Total of 300 station blocks, 298 free
Codes: P - permanent, S - self
Bridge Group 1:
Address Action Interface Age RX count TX count
0010.5afb.36cb forward Serial0.1 0 1809 0
What could be the reason that it will not work with X.25 encapsulation ? Could it be a an problem with the address resolution or an IOS Bug?
I think that the Router B maybe can not deencapsulate the packet from the X.25 frame because in the the X.25 frame is no information of the next Layer (Ethernet V2 Frame) or packet that is carrierd in the frame.
With an WAN Analyzer we recognized that both PPP and HDLC (which both worked) have Informations about the packet (802.3) that is carried in the Frame.
1 REPLY
Bronze
Re: Transparent Bridging over X.25 and BVI Interface (IRB)
I suspect that IRB over X25 is just not supported although I could not find it documented anywhere. I know that it definately is not supported over ISDN although I don't believe that is documented either.
97
