Transport input None
What is the draw back of configuring a "Transport Input None" under Con 0?
Line Con 0
Transport Input None.
If somebody inserts this command through Telnet Sessions then will it be a problem getting into a router through Console mode.
I am not able to console into a router. I pulled up the Old config and saw that the Line Con 0 had Transport Input None configured.
1 REPLY
Silver
Re: Transport input None
Take a look at:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ftersv_r/trftrx.htm#1094613
Anyway, you can try configuring 'transport input all'
665
