Community Member
Trouble while using giga etherchannel with 2950-3550 in MAC environnment
I try to configure an etherchannel between a 2950 and a 3550 with 2 giga ports. The configuration seems to be ok because when pluging the second port from the channel it works ok. The problems occurs from time to time with disconnection from the MACintosch. Thei loss connectivity. I don't think it is a stp issue because I can still access the switch for administration. The etherchannel is a 802.1q link .
An idea?
1 REPLY
Silver
Re: Trouble while using giga etherchannel with 2950-3550 in MAC
Have you checked the CPU utilization using the show processes cpu command? The following document might be of help.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080176720.shtml
120
