trouble with isdn ddr
tomredmond
I am trying to get a 1720 to use a isdn bri link for traffic to one ip address. However I can't get it to lift the line. If I manually lift the line it routes the packet ok. I used debug for isdn events and ppp authentication and dialer and got no output. the only response was from DEBUG IP PACKET 101 the result of which is below with the config.
All help appreciated
sh run
Building configuration...
Current configuration : 2636 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname bort
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Loopback0
ip address 49.49.49.49 255.255.255.255
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication chap
interface FastEthernet0
ip address 56.35.31.1 255.255.128.0
speed auto
half-duplex
no cdp enable
interface Serial0
no ip address
ip helper-address 56.200.127.255
ip directed-broadcast
encapsulation frame-relay
no fair-queue
frame-relay lmi-type ansi
interface Serial0.16 point-to-point
description Backup PVC to HQ
bandwidth 256
ip address 56.5.49.129 255.255.255.128
ip ospf authentication-key cisco
ip ospf cost 4000
no cdp enable
frame-relay class data
frame-relay interface-dlci 16
frame-relay payload-compression packet-by-packet
interface Serial0.17 point-to-point
description Primary link to longman
bandwidth 256
ip address 56.5.49.1 255.255.255.128
no cdp enable
frame-relay interface-dlci 17
interface Dialer1
ip address 56.3.10.2 255.255.255.128
encapsulation ppp
dialer pool 1
dialer remote-name INVER
dialer string .........
dialer-group 1
no cdp enable
ppp chap hostname I_BORT
ppp chap password 7 121016131C535B162524
router ospf 100
log-adjacency-changes
area 0.0.0.49 authentication
area 0.0.0.49 stub
area 0.0.0.100 authentication
area 0.0.0.100 nssa
redistribute connected metric 2000 metric-type 1 subnets
network 56.5.49.1 0.0.0.0 area 0.0.0.49
network 56.5.49.129 0.0.0.0 area 0.0.0.100
network 56.35.31.1 0.0.0.0 area 0.0.0.49
--More-- ip classless
ip route 0.0.0.0 0.0.0.0 56.3.10.1
ip route 56.200.4.18 255.255.255.255 56.3.10.1
no ip http server
map-class frame-relay data
no frame-relay adaptive-shaping
frame-relay cir 192000
frame-relay bc 192000
frame-relay be 64000
frame-relay mincir 192000
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx deny
no cdp run
snmp-server community public RO
snmp-server community private RW
snmp-server host 56.200.91.65 private
banner motd ^Cbort_router^C
line con 0
line aux 0
line vty 0 4
login
end
bort#debug isdn events
ISDN events debugging is on
bort#debug ppp authentication
PPP authentication debugging is on
bort#term mon
bort#ping 56.200.4.8 18
Sending 5, 100-byte ICMP Echos to 56.200.4.18, timeout is 2 seconds:
Success rate is 0 percent (0/5)
bort#debug ip packet 101
IP packet debugging is on for access list 101
bort#
bort#ping 56.200.4.18
9w1d: IP: s=56.3.10.2 (local), d=56.200.4.18 (Dialer1), len 100, sending
9w1d: IP: s=56.3.10.2 (local), d=56.200.4.18 (Dialer1), len 100, encapsulation failed
bort#
5 Replies 5
deilert
Level 6
Level 6
What is the ip of the host on the remote side ? is it 56.200.4.18 ? If it is you are not on the same subnet .
Also check the route back
rlcarr
If you show your ISDN status does your Layer 2 report back that your
SPIDs are valid? does it show the carrier has got a valid TEI?
If you show your dialer 1 does he show up and spoofing?
Also, you are going to have some OSPF problems, you've created an ABR that isn't connected via area 0.
~rlc
CCNP, CCDA, CNE
Thanks for your prompt response. I am in the UK so the isdn flavour is basic-net3 (no spid's) I've included the output SH ISDN STATUS and SH DIALER1 They look fine and as I say it all works fine if I manually lift the line.
As to the OSPF area 0.0.0.0 is attached to the core router but not on the sub-interfaces attached to this router.
bort#sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 116, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 64
Total Allocated ISDN CCBs = 0
bort#
bort#sh int dialer1
Dialer1 is up (spoofing), line protocol is up (spoofing)
Hardware is Unknown
Internet address is 56.3.10.2/25
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
DTR is pulsed for 1 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 9w1d
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
22322 packets input, 2459897 bytes
5293 packets output, 691983 bytes
It looks like the route to the dialer is working. The encap failed is normal on a ddr line until it comes up. Turn on all isdn debugs and debug dialer and see if it is trying to call and what is happening.
Here is the result of the debugging you suggested.
bort#debug isdn l2-Sock-Proc
ISDN L2 Socket Process packets debugging is on
bort#debug isdn q921
ISDN Q921 packets debugging is on
bort#debug isdn q931
ISDN Q931 packets debugging is on
bort#debug dialer events
Dial on demand events debugging is on
bort#debug dialer forwarding
Dialer forwarding events debugging is on
bort#debug dialer map
Dial on demand dynamic dialer maps debugging is on
bort#debug dialer packets
Dial on demand packets debugging is on
bort#term mon
9w2d: Di1 DDR: ip (s=56.3.10.2, d=56.200.4.18), 100 bytes, outgoing interesting
(ip PERMIT).
(ip PERMIT).
(ip PERMIT).
(ip PERMIT).
(ip PERMIT).
