Webcast-Catalyst9k
trouble with vPC
Please tell me why the secondary in my vPC pair of Nexus 5k's give this failure error and the primary shows no connection errors at all:
sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : failed
Type-2 inconsistency reason       : SVI type-2 configuration incompatible
vPC role                          : secondary
Number of vPCs configured         : 0
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1-2,18,28,50,120,140
 Check the VLAN allowed in
Check the VLAN allowed in peer-link interface on both the switches.
Go to vPC peer link interface and check allowed vlan's
HI , Best to do a "show vpc
HI ,
Best to do a "show vpc consistency-parameters global" and ensure all your
vlans between the N5K pairs are the same. It will show you table comparing the parameters set on both N5Ks so you could easily spot the difference. :)
HTH.
Jay Ocampo
70
