Trouble with wireless bridges and Catalyst
I have 2 catalyst 3550 connected to 2 bridges connecting 2 buildings. But when I try to pass traffic greater than 1400 bytes, these packets are dropped. If I send pings from one side to other there is no problem.
Somebody know if I need to configure something else? or change something in the catalyst?
I have cdp and spanning tree disabled.
Re: Trouble with wireless bridges and Catalyst
Are the ports connecting the wireless bridges setup as access ports as any VLAN tagging for ISL or 802.1q may push the frame over the MTU of the wireless bridge.
Hi steven,
No, the ports in the switches are configured as access ports I'm not using trunking.
Well, I will assume that you have the the Cisco Aironet bridges, make sure that the "fragment-threshold" on the bridge is NOT less than the Concatenation size.
If you have an Aironet bridge on one side and a different bridge on the other side, try to change the payload-encapsulation to RFC1042 on the Aironet.
hope it helps
86
