troubleshoot wan connection
any and all suggestions welcomed.
I have a remote site on a 1721 router connected to two core routers both 3660's by frame relay pvc's. One link is suppost to be a redundant link to the other. The two links are in two seperate subnets.
I can traceroute and or telnet from the core to the remote router but I cannot ping.
I can also traceroute/telnet from the remote router to the core and beyond but I can't ping.
I can ping from a pc in the core to either of the remote interfaces but a traceroute fails.
The ospf is not being shared and the ip ospf neighbor command say the state is EXSTART or down all though the neighbor id is correct.
I am happy to supply config's answer questions etc
Tom Redmond
Re: troubleshoot wan connection
I would like to analyze the configs at either ends..
they are posted in reply to another response below
Tom
Silver
Tom,
1. Your OSPF issue might very well be mismatched interface types (timers). Ensure all of your interfaces are same type (point to point (or point to multipoint). (debug ip ospf adjacency on your routers will tell you if you have mismatched interface types (timers))
2. Need to see your frame mapping statements to tell on the ping / traceroute issue.
Hope this helps you,
Don
1. all interfaces are point to point
2.the mapping statements are
Serial0.16 (up): point-to-point dlci, dlci 16(0x10,0x400), broadcast
status defined, active
Serial0.17 (up): point-to-point dlci, dlci 17(0x11,0x410), broadcast
the mapping statements from the two core routers are huge but the equivalent dlci's are broadcast status defined, active as above.
hope this sheds some light.
Tom
Bronze
Tom,
In your remote router, enter "show frame-relay pvc" and verify that your PVCs are up, and that they have been up for a long time. If they have not been up for a while, the PVCs are probably bouncing, which would explain how the OSPF neighbor state never gets beyond EXSTART. Enter the command "show frame-relay lmi" and see if you have a significant number of status timeouts. Either bouncing PVCs or LMI status timeouts can indicate a bad connection between your router and the frame relay switch. You can check your portion with a show interface command for your frame relay interface. Look at the error count. Repeat the command a number of times to see if the errors are incrementing. Errors on your interface can explain bouncing PVCs and LMI status timeouts. If you have a clean line and your PVCs are not staying up or you have LMI status timeouts, there is a problem in your frame relay provider's network.
Also, in the core routers and in the remote router, look at the output from the "show frame-relay map" command and make sure that you have the IP address-to-DLCI mappings that you expect.
I won't point you towards the connections at the core, since they are both behaving the same way, and I assume that those routers have working PVCs to other locations on the same interfaces.
That should give you a start. Good luck.
Mark
the output from the remote router of the various commands you suggested are posted below. I think the frame-relay side of thihgs is ok but......
I do have multiple other connections at the core that are fine.
bar#sh frame-relay pvc
PVC Statistics for interface Serial0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 2 0 0 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 16, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0.16
input pkts 3850 output pkts 3015 in bytes 210768
out bytes 190896 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 2947 out bcast bytes 185696
pvc create time 04:05:50, last time pvc status changed 04:05:50
DLCI = 17, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0.17
input pkts 1799 output pkts 4793 in bytes 118261
out bytes 316323 dropped pkts 0 in FECN pkts 0
out bcast pkts 2922 out bcast bytes 184436
pvc create time 04:05:51, last time pvc status changed 04:05:51
bar#sh fra
bar#sh frame-relay lmi
LMI Statistics for interface Serial0 (Frame Relay DTE) LMI TYPE = ANSI
Invalid Unnumbered info 0 Invalid Prot Disc 0
Invalid dummy Call Ref 0 Invalid Msg Type 0
Invalid Status Message 0 Invalid Lock Shift 0
Invalid Information ID 0 Invalid Report IE Len 0
Invalid Report Request 0 Invalid Keep IE Len 0
Num Status Enq. Sent 1477 Num Status msgs Rcvd 1477
Num Update Status Rcvd 0 Num Status Timeouts 0
bar#sh frame
bar#sh frame-relay map
Bronze
Tom,
How about "show interface s0"?
Mark
here you go hope it helps
Bar#sh int s0
Serial0 is up, line protocol is up
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation FRAME-RELAY, loopback not set
Keepalive set (10 sec)
LMI enq sent 1974, LMI stat recvd 1974, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 7929/0, interface broadcasts 792
9
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 05:29:04
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 2000 bits/sec, 3 packets/sec
14916 packets input, 3721160 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort
11918 packets output, 670074 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Bar#
Bronze
Tom,
All of this looks clean. Did you do the debugging that Don recommended earlier?
Mark
As DONEWALD suggested I used the command DEBUG IP OSPF ADJ, however nothing happened i.e. no messages.
I've included the relevent configs for the three routers involved below. Hopefully someone can spot the problem.
Tom Redmond
Remote router configs
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Bar
**** password bit
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 84.84.84.84 255.255.255.255
interface FastEthernet0
ip address 52.72.31.1 255.255.128.0
speed auto
half-duplex
no cdp enable
interface Serial0
no ip address
ip helper-address 52.200.127.255
ip directed-broadcast
encapsulation frame-relay
no fair-queue
frame-relay lmi-type ansi
interface Serial0.16 point-to-point
description Primary PVC to HQ
bandwidth 64
ip address 52.5.84.1 255.255.255.128
ip ospf authentication-key cisco
no cdp enable
frame-relay class data
frame-relay interface-dlci 16
interface Serial0.17 point-to-point
description Backup link to Long
bandwidth 64
ip address 52.5.84.129 255.255.255.128
ip ospf cost 4000
no cdp enable
frame-relay interface-dlci 17
router ospf 100
log-adjacency-changes
area 0.0.0.84 authentication
area 0.0.0.84 stub
area 0.0.0.100 authentication
area 0.0.0.100 nssa
redistribute connected metric 2000 metric-type 1 subnets
network 52.5.84.1 0.0.0.0 area 0.0.0.84
network 52.5.84.129 0.0.0.0 area 0.0.0.100
network 52.72.31.1 0.0.0.0 area 0.0.0.84
ip classless
ip forward-protocol udp 1604
ip route 0.0.0.0 0.0.0.0 52.5.84.130
no ip http server
map-class frame-relay data
no frame-relay adaptive-shaping
frame-relay cir 48000
frame-relay bc 48000
frame-relay be 16000
frame-relay mincir 48000
no cdp run
snmp-server community public RO
snmp-server community private RW
snmp-server host 52.200.91.65 private
**** password bit ****
end
hq core router config
version 12.2
hostname hq
loads of stuff about isdn left out
memory-size iomem 10
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
description LAN PORT
ip address 52.200.33.7 255.255.128.0
no ip redirects
duplex auto
speed auto
no cdp enable
standby 1 ip 52.200.33.9
standby 1 priority 110
standby 1 preempt
interface Serial1/0
description main frame relay bearer
no ip address
no ip mroute-cache
no fair-queue
serial restart_delay 0
approx 30 other sub interfaces left out
interface Serial1/0.134 point-to-point
description Primary PVC to Bar
bandwidth 64
ip address 52.5.84.2 255.255.255.128
no ip mroute-cache
no cdp enable
frame-relay interface-dlci 34
frame-relay payload-compression packet-by-packet
interface Serial1/1
no ip address
shutdown
no cdp enable
interface Serial1/2
no ip address
shutdown
no cdp enable
interface Serial1/3
no ip address
shutdown
no cdp enable
load of dialer definitions left out
router ospf 100
area 0.0.0.0 authentication
area 0.0.0.84 stub
area 0.0.0.100 nssa default-information-originate
network 52.5.84.2 0.0.0.0 area 0.0.0.84
network 52.5.84.128 0.0.0.127 area 0.0.0.100
network 52.200.33.7 0.0.0.0 area 0.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 52.200.33.1
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
no cdp run
snmp-server engineID local 00000009020000049A37F6A0
password bit
end
2nd core router config
version 12.2
hostname Long
password bit
ip subnet-zero
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 52.200.33.8 255.255.128.0
no ip redirects
duplex auto
speed auto
no cdp enable
standby 1 preempt
interface Serial1/0
no ip address
no ip mroute-cache
no fair-queue
sub interfaces missed out
interface Serial1/0.148 point-to-point
bandwidth 64
ip address 52.5.84.130 255.255.255.128
ip ospf cost 4000
no ip mroute-cache
no cdp enable
frame-relay interface-dlci 48
interface Serial1/1
no ip address
shutdown
no cdp enable
interface Serial1/2
no ip address
shutdown
no cdp enable
interface Serial1/3
no ip address
shutdown
no cdp enable
router ospf 100
area 0.0.0.84 stub
network 52.5.84.0 0.0.0.127 area 0.0.0.84
network 52.5.84.130 0.0.0.0 area 0.0.0.100
network 52.200.33.8 0.0.0.0 area 0.0.0.0
ip classless
no ip http server
ip pim bidir-enable
map-class frame-relay 3com
frame-relay cir 64000
frame-relay bc 64000
frame-relay be 0
frame-relay mincir 64000
no cdp run
snmp-server engineID local 00000009020000049A134B90
password bit
end
\f1
re my message above I forgot to send output to terminal DOH! here is the result of the DEBUG IP OSPF ADJ
19:17:32: OSPF: Send DBD to 2.2.2.2 on Serial0.17 seq 0x2CC opt 0x48 flag 0x7 len 32
19:17:32: OSPF: Retransmitting DBD to 2.2.2.2 on Serial0.17 [1]
19:17:33: OSPF: Rcv hello from 1.1.1.1 area 0.0.0.84 from Serial0.16 52.5.84.2
19:17:33: OSPF: End of hello processing
19:17:33: OSPF: Send DBD to 1.1.1.1 on Serial0.16 seq 0x1954 opt 0x40 flag 0x7 len 32
19:17:33: OSPF: Retransmitting DBD to 1.1.1.1 on Serial0.16 [4]
19:17:37: OSPF: Send DBD to 2.2.2.2 on Serial0.17 seq 0x2CC opt 0x48 flag 0x7 len 32
19:17:37: OSPF: Retransmitting DBD to 2.2.2.2 on Serial0.17 [2]
19:17:37: OSPF: Rcv hello from 2.2.2.2 area 0.0.0.100 from Serial0.17 52.5.84.130
19:17:37: OSPF: End of hello processing
many repeats of above
19:18:23: OSPF: Killing nbr 1.1.1.1 on Serial0.16 due to excessive (13) retransmissions
19:18:23: OSPF: 1.1.1.1 address 52.5.84.2 on Serial0.16 is dead, state DOWN
19:18:23: %OSPF-5-ADJCHG: Process 100, Nbr 1.1.1.1 on Serial0.16 from EXSTART to DOWN, Neighbor Down
: Too many retransmitio
19:18:27: OSPF: Send DBD to 2.2.2.2 on Serial0.17 seq 0x2CC opt 0x48 flag 0x7 len 32
19:18:27: OSPF: Retransmitting DBD to 2.2.2.2 on Serial0.17 [12]
19:18:27: OSPF: Rcv hello from 2.2.2.2 area 0.0.0.100 from Serial0.17 52.5.84.130
19:18:27: OSPF: End of hello processing
19:18:27: OSPF: Build router LSA for area 0.0.0.84, router ID 84.84.84.84, seq 0x8000001D
19:18:27: OSPF: Build router LSA for area 0.0.0.100, router ID 84.84.84.84, seq 0x8000001D
19:18:32: OSPF: Send DBD to 2.2.2.2 on Serial0.17 seq 0x2CC opt 0x48 flag 0x7 len 32
19:18:32: OSPF: Retransmitting DBD to 2.2.2.2 on Serial0.17 [13]
19:18:33: OSPF: Rcv hello from 1.1.1.1 area 0.0.0.84 from Serial0.16 52.5.84.2
19:18:33: OSPF:
OSPF: Nbr 1.1.1.1 52.5.84.2 Serial0.16 is currently ignored
19:18:37: OSPF: Killing nbr 2.2.2.2 on Serial0.17 due to excessive (13) retransmissions
19:18:37: OSPF: 2.2.2.2 address 52.5.84.130 on Serial0.17 is dead, state DOWN
19:18:37: %OSPF-5-ADJCHG: Process 100, Nbr 2.2.2.2 on Serial0.17 from EXSTART to DOWN, Neighbor Down
: Too many retransmitions
19:18:37: OSPF: Rcv hello from 2.2.2.2 area 0.0.0.100 from Serial0.17 52.5.84.130
19:18:37: OSPF:
OSPF: Nbr 2.2.2.2 52.5.84.130 Serial0.17 is currently ignored
bar#
19:18:43: OSPF: Rcv hello from 1.1.1.1 area 0.0.0.84 from Serial0.16 52.5.84.2
19:18:43: OSPF:
19:18:47: OSPF: Rcv hello from 2.2.2.2 area 0.0.0.100 from Serial0.17 52.5.84.130
19:18:47: OSPF:
bar#no debug all
All possible debugging has been turned off
bar#
Can you provide us the routing table?
I think you cannot do this at the same time:
Since the 52.72.31.1 is the addr of eth and you put this net on the area 84, the redistributed connected do this for you.
And i think too that area 84 should be nssa.
Silver
Tom
Prior to looking at the OSPF at L3 I would ensure my PVC's were mapped properly.
My suggestions
1. turn on cdp see what you get. make sure your DLCI's at the remote side are mapped to the proper interfaces, the carrier could just have them reveresed.
2. if every thing is mappered properly , remove the FR traffic shaping parameters.
It looks to me that your PVC's are not mapped properly
I did what you asked, the result is below. The crossed pvc's did occur to me and I checked with the provider and I think the results below show that they are ok.
However one odd thing on debug ip ospf adj output I noticed a line stating "could not see ourselves in hello" . Hello packets are being traded but the negotiation seems to be failing.
There is no frame-relay adaptive shaping.
Bar#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
hq Ser 0.16 134 R 3660 Ser 1/0.134
Long Ser 0.17 133 R 3660 Ser 1/0.148
Silver
'Can you ping across the PVC's when sourcing the ping ?
ping 52.5.84.2 sourcing from 52.2.84.1
I would also remove all parameters from the interface other than the ip address and the FR int DLCI commands , see if it works just with a bare bones config. maybe you have a spave in your PW for authentication .
I did a few pings and traceroutes to illustrate the problems. The 52.200.33.1 address at the end is a pc on our core LAN.
From that pc or any other on the LAN I can ping all the interfaces involved but I cannot traceroute to them. I can however telnet to them.
bar#ping
Protocol [ip]:
Target IP address: 52.5.84.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 52.5.84.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 52.5.84.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
bar#ping
Protocol [ip]:
Target IP address: 52.5.84.130
Repeat count [5]:
Sending 5, 100-byte ICMP Echos to 52.5.84.130, timeout is 2 seconds:
bar#ping 52.5.84.2
bar#trac
bar#traceroute 52.5.84.2
Tracing the route to 52.5.84.2
1 52.5.84.2 48 msec * 40 msec
bar#traceroute 52.5.84.130
Tracing the route to 52.5.84.130
1 52.5.84.130 68 msec * 52 msec
bar#ping 52.200.33.1
Sending 5, 100-byte ICMP Echos to 52.200.33.1, timeout is 2 seconds:
bar#tracer
bar#traceroute 52.200.33.1
Tracing the route to 52.200.33.1
1 52.5.84.130 64 msec 60 msec 60 msec
2 52.200.33.1 60 msec 60 msec 60 msec
Silver
Tom
If you can not ping directly connected netwrorks your OSPF will never establish a relationship.
You can trace because it is going around since the interface are up your traces are successful.
Try a few things
try clearing the CEF and or route-cache
try removing the ip helper from the serial interface
try going with a bare bones config
try making your subnet masks 30 bits
If all of this fail I would open a ticket with the FR provider telling them you are not able to pass data , .
I went with a barebones config on the primary link i.e. serial0.16 on remote router and serial1/0.134 on hq core router and I can now ping on that link.
I removed the ip helper address, ip ospf authentication-key, frame-relay compression and the ip directed broadcast. I will try add ing them one at a time and see at what point it fails but any suggestions are welcome.
Bronze
it looks like you have area 0.0.0.84 connected to area 0 and at the remote router to area 0.0.0.100, which is also connected to area 0. So when the data takes the path through area 0.0.0.100 it needs a virtual link. When it takes the other path it does not. I'm not sure you can make it work this way but try making area 0.0.0.100 a virual link. Or clean it up and use area 0.0.0.84 throughout.
Bronze
To make the virtual link work you will also need to specify area 0 authentication on the remote router.
239
