Webcast-Catalyst9k
Trunk between 3550-12T and 2950T
What is the configuration for 1000mbps trunk connection between a 3550-12T cu port and a 2950T-24 10/100/1000 baseT port? Here is what I think it should be:
On the 3550-12T, interface GigabitEthernet0/1
switchport trunk encapsulation dot1q (comment: we always opt for dot1q)
switchport mode trunk
no ip address
duplex full
speed 1000
Set up the same on interface GigabitEthernet0/1 on the 2950T-24, as follows:
no ip address
duplex full
speed 1000
OR, simply
on the 3550-12T:
no ip address
on the 2950T:
no ip address
I am a bit of a novice when it comes to configuring 1000BaseT ports. We have always hard coded the speed and duplex. Is this considered acceptable, or even good? Please advise. TIA. Russ.
1 REPLY
Bronze
Re: Trunk between 3550-12T and 2950T
I believe that would be enough. Just keep in mind that if you hard-coded the speed and duplex, it should be done on both ends of the link. You can check out the example below for trunking between 3550 and a switch running IOS:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010f615.shtml
HTH.
106
