01-23-2002 07:23 AM - edited 03-01-2019 08:10 PM
I'm doing a trunk between a cat 3500 and a router 2600, and i have 2 subinterfaces (e0/0.1 and e0/0.2) in the router, and the port of the switch if FastEthernet. I'm doing encaptulation with 802.1q and i'm only having layer 2 (cdp works well), but i have not layer 3. I put the switch port (the trunk one) to run at 10Mbps (because the ethernet on router support only 10).
Why isn't working, is it able to work?
Thanks!
omarg
01-23-2002 07:33 AM
It's only because 802.1q is not suported on 10Mbps interfaces.
You need a FastEthernet interface on your 2600.
Regards.
01-23-2002 07:37 AM
Ok, and if i do it with isl???
will it work?
omarg
01-23-2002 07:59 AM
Bad luck, ISL and trunking in general needs a Fast Ethernet interface
01-23-2002 09:27 AM
Ok, thanks anyway...
omarg
01-27-2002 11:38 PM
I am essentially trying to do the same with a 2520 and 2948GL3. Will it be possible if I install a Fast Ethernet interface on the 2520 ?
