Trunk connection Cisco 2950 with Foundry FastIron
I am trying to connect Cisco 2950 with Foundry FastIron via trunk . I have connected two ports from each switch and i have made the following config.But it doesnt work . Any ideas .
CISCO
interface Port-channel1
no ip address
flowcontrol send off
interface FastEthernet0/1
no ip address
channel-group 1 mode active
channel-protocol lacp
interface FastEthernet0/2
no ip address
From Foundry site just enable the link-aggregate command to the interfaces .
Makis
1 REPLY
Bronze
Re: Trunk connection Cisco 2950 with Foundry FastIron
If you are not getting even trunk links not coming up, disable autonegotiation at Cisco switch. And another possible solution is enable link-aggregate in ACTIVE mode at Foundry fastIron switch.
232
