Trunk uplinks problem
I have a strange problem on two links in my network that I can't figure out. I have problems with one 6509 1000BaseSX module that has two ports connecting to two other 6509's as redundant links. Every so often they will drop out of STP with "%PAGP-5-PORTFROMSTP:" error and soon after will come back. I first reseated the links and then replaced the patch cables but the problem keeps occurring every so often. They seem to run OK for about a week after I replaced the patches/reseted. Suspect the module might have something going on. Any ideas? Thanks.
Versions are 5.4(2)FW and 5.5(12)Sw
Re: Trunk uplinks problem
Do you have etherchannel configured on these two links ?
Give a "show port capabilities" on either ends to see whether all parameters on both links have been set properly.
Can you also paste the rest of the error message that pops up. (that means, the message that comes after "%PAGP-5-PORTFROMSTP).
We do not have EtherChannel config'd on these, below is output taken from one of the links with the alarms listed from today.
SW12 3/3 connnects to SW13 2/1
SW12
sw12> (enable) show port capabilities 3/3
Model WS-X6416-GE-MT
Port 3/3
Type 1000BaseSX
Speed 1000
Duplex full
Trunk encap type 802.1Q,ISL
Trunk mode on,off,desirable,auto,nonegotiate
Channel yes
Broadcast suppression percentage(0-100)
Flow control receive-(off,on,desired),send-(off,on,desired)
Security yes
Membership static,dynamic
Fast start yes
QOS scheduling rx-(1p1q4t),tx-(1p2q2t)
CoS rewrite yes
ToS rewrite DSCP
UDLD yes
Inline power no
AuxiliaryVlan no
SPAN source,destination
COPS port group not supported
003 Nov 10 06:49:57pst -08:00 %PAGP-5-PORTFROMSTP:Port 3/3 left bridge port 3/3
2003 Nov 10 06:49:58pst -08:00 %DTP-5-NONTRUNKPORTON:Port 3/3 has become non-trunk
2003 Nov 10 06:54:15pst -08:00 %DTP-5-TRUNKPORTON:Port 3/3 has become isl trunk
2003 Nov 10 06:54:17pst -08:00 %PAGP-5-PORTTOSTP:Port 3/3 joined bridge port 3/3
SW13
sw13> (enable) sh port capabilit 2/1
Model WS-X6K-SUP1A-2GE
Port 2/1
Type 1000BaseSX
Speed 1000
Duplex full
Channel yes
Security yes
Fast start yes
CoS rewrite yes
ToS rewrite DSCP
UDLD yes
Inline power no
AuxiliaryVlan no
2003 Nov 10 06:49:53pst -08:00 %PAGP-5-PORTFROMSTP:Port 2/1 left bridge port 2/1
2003 Nov 10 06:49:53pst -08:00 %DTP-5-NONTRUNKPORTON:Port 2/1 has become non-trunk
Since there is no etherchannel configured, STP will run between the switches on both links and one of them will be in forwarding state and the other in blocking state. The above error messages could be due to a link flap. How often are you getting this messages ?
It varies, sometimes it happens a couple of times a day and other times it goes without an error msg for a week. That is why its kind of hard to pinpoint it. I appreciate your help.
132
