Community Member
Trunk with 802.1q and ISL
I know that I cannot have 802.1q and ISL on the same trunk link, but say I have three switches cascaded with trunk links with ISL trunk to one switch and 802.1q other switch, will all vlan, vtp trunk info be functional.
1 ACCEPTED SOLUTION
Re: Trunk with 802.1q and ISL
Yes, it should work with no problem.
The only problem could be with VLAN numbers higher then 1000 (some CatOS and IOS versions don't support VLAN numbers higher then 1024 on 802.1q).
Milan
Yes..You can do it
Milan
Community Member
Thanks all, vlans not a worry I have 5 to propogate and dont use any of the defualt or higher than 999.
90
