Community Member
Trunking Problem Catalyst 2924-M-XL
I have a catalyst 2924-M-XL with IOS 11.2(8)SA5. I cannot use this catalyst for Trunking to other switch because the IOS is standard version. So, I am tried to upgrade with Enterprise version such as, IOS 12.0(5)SA5. After the upgrade, my catalyst system LED is amber (never turn to green). The trunk configuration is okay but the other configuration have a problem, such cdp and etc.
Anyone have problem like this before ???
Thank you.
1 REPLY
Silver
Re: Trunking Problem Catalyst 2924-M-XL
Have you made sure that the upgrade was done properly. Did you check the checksum? Have you seen any error messages?
You could take a look at the steps to upgrade at the link given below.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc/rn/1061504.htm#xtocid558628
92
