Community Member
Trying to interconnect Catalyst 3750 with cwdm sfp module
hi,
I try to interconnect 2 Catalyst 3750 switch use cwdm sfp fiber module.
If just plug in, there is no link between 2 switchs.
What's the procedure to make this?
Community Member
Re: Trying to interconnect Catalyst 3750 with cwdm sfp module
you have 2 options with CWDM at the moment. the first option is to use any or all to the 8 wavelenght SFPs: CWDM-SFP-1470= (gray) thru CWDM-SFP-1610= (brown)
with passive multiplexers (MUX) as described here:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet09186a00801a557c.html
or
In the off chance you have only a single strand of fiber available, you would choose:
1000BASE-BX10-D AND 1000BASE-BX10-U SFP FOR SINGLE-FIBER BIDIRECTIONAL APPLICATIONS
as described here:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html
Overall, CWDM is a cost effective method of building a Metro-Ethernet LAN / SAN by providing a single pair of single mode fiber the ability to support 8 wavelengths. You can mix and match these wavelengths with 1Gb Ethernet or 2Gb FiberChannel as needed.
rate if helpful
thanks,
Community Member
If i understand your response, i must to use one of these exactly references to interconnect my switch.
I would like to know what parameters to assign at the gigabit ethernet port where is plug th SFP module.
I hope you understand my approximately english!
Thanks a lot for your council.
Best regards
Community Member
There is no special configuration required on the switch. It will recognize the CWDM SFP as a supported transceiver and the interface will look as follows:
GigabitEthernet0/49 is up, line protocol is up (connected)
Full-duplex, 1000Mb/s, link type is auto, media type is CWDM-1510 SFP
Follow the diagrams and use the Multiplexers (MUXs) where necessary.
Sincerely,
497
