Trying to reinitialize DB and 'cmf' is not a valid data source
I have been trying to add devices to RME with no luck. I am running into DDTS CSCin56596 which says to reinitialize the database. Well I did once andn then I tried to import from a csv file and the device import failed again. So this time I was going to reinitialize the DB again but add the devices manually one at a time to see if that would work. Well this time I can't reinitialize the CMF database I get:
C:\Program Files\CSCOpx\bin>dbRestoreOrig.pl dsn=cmf dmprefix=Cmf
'cmf' is not a valid data source for the product.
Also, when I run the self test that the ODBC test fails.
In the ODBC Data Source Administrator I do not see a System DSN for cmf only rme. Is there a acript to create the dsn? I don't know what to enter if I did it manually. Or, should I re-install the whole thing since it's a new install anyway?
Darrick
Re: Trying to reinitialize DB and 'cmf' is not a valid data sour
Mine looks like this:
C:\progra~1\CSCOpx\bin\perl C:\progra~1\CSCOpx\bin\dbRestoreOrig.pl dsn=cmf dmprefix=Cmf
hope this helps
pat
Thanks for the response. I get the same message with that also.
C:\Program Files\CSCOpx\bin>C:\progra~1\CSCOpx\bin\perl C:\progra~1\CSCOpx\bin\d
Do you have a System DSN entry for 'cmf' in the ODBC Administrator?
Darrick
Go to CSCOpx/database/cmf and see if the cmf.db is present.  If the DB is not present, then something seriously is wrong. If you are unable to purge the db using NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=cmf dmprefix=Cmf, you will need reinstall LMS. Or if you have a backup, run a restore from the last known good backup.
"If this post answers your question, please click the "Correct Answer" button"
307
