tuning of bgp dampening
If someone knows what are the parameters normally used in bgp dampening for a perfect work.
I thought that they can be:
half-life: 10 minutes
reuse: 750
suppress-value:2000
max-suppress-time: 40 minutes
Are those correct or I have to review all?
Thank you.
Regards.
Paolo
Re: tuning of bgp dampening
Hello Paolo,
This parameters will depend on your network and how frequently you see the flappings.
There are some default values though:
half-life-time
Defines the amount of time in minutes after which a penalty is reduced by half. Valid values are 10 - 45 minutes. Default: 15 minutes.
reuse-value
Defines the accumulated penalty amount at which the route is re-advertised. Valid values are 500 - 20000.
Default: 750.
suppress-value
Defines the accumulated penalty amount at which the route is suppressed. Valid values are 500 - 20000.
Default: 2000.
maximum-suppress-time
Defines the maximum time in minutes that a route is suppressed. Valid values are 1 - 90.
Default: 60 or 4 times the value of half-life time.
You''ll need to take a better look on the routes you are tracking and tune the values.
Check the following link for such a study:
http://ftp.iasi.roedu.net/mirrors/ftp.ripe.net/presentations/ripe-m25-tbarber-bgp-damp.html
HTH,
please remember to rate helpful posts.
Vlad
I would like to know how to protect important routes from dampening.
If I put into a route map a match with an access-list that permit a default route and after this I create a bgp dampening rule.
I would like to know if this works (don't dampen the dafault route).
Thank you
regards.
Paolo
NANOG doesn't really recommend dampening anymore.
Same with RIPE:
http://www.ripe.net/ripe/docs/ripe-378.html
If this is for a test, go ahead, but if this is operational, I would find an operators group or other suitable reference.
Most of the email/news group feeds that encourage route dampening are from the 90s and have been superceded by the current recommendations.
Good point from Andrew.
I usually only give straight tech advises, about what is asked.
In this case, I would answer, yes, you can specify specifics routes on the route-map to dampening the routes you want.
Vlad
158
