Webcast-Catalyst9k
Two active links to the same network?
I'm wondering if it's possible to have two active links to the same network?
Reason is that a Frame-Relay connection from Tokyo to Singapore is very expensive.
I could like get an Internet connection and run all my non-mission critical applications over VPN, and my mission critical over the Frame-Relay. I want the mission critical data to go over the Frame-Relay since it has higher uptime then Internet can provide, and if Internet goes down for some reason, my applications don't time out.
I have heard that layer 5 routing could work for this. Does anybody know, or have a solution or an idea where to find this information.
Lars
Re: Two active links to the same network?
You may try Policy based routing.
Thanks, I'll look into it.
87
