two adsl lines' problem?Can it be done?
My company has bought two adsl lines from a isp for accessing the Internet.I have a 1721 router and two wic-1adsl cards.Now I want to use these lines increasing the bandwidth,but I don't like to use policy-based routing by dividing the inside network.I hope the inside users can select a random route.
Can this be done?
I had a config but it didn't work well.
interface f 0
ip add x.x.x.x x.x.x.x
ip nat inside
interface atm 0
no ip add
interface atm 1
no ip add
interface dialer1
ip address nego
ip nat outside
ip mtu 1492
dial-group 1
dial-pool 1
encap ppp
ppp authen pap
ppp pap sent xxx pass xxx
interface dialer2
ip address nego
ip nat outside
ip mtu 1492
dialer-group 1
dialer-pool 2
encap ppp
ppp authen pap
ppp pap sent yyy pass yyy
ip route 0.0.0.0 0.0.0.0 dialer1
ip route 0.0.0.0 0.0.0.0 dialer2
ip nat inside source route-map adsl1 interface dialer1 overload
ip nat inside source route-map adsl2 interface dialer2 overload
route-map adsl1 permit 10
match ip address 1
match interface dialer1
route-map adsl2 permit 10
match ip address 1
match interface dialer2
access-list 1 permit any
dialer-list 1 protocol ip permit
Thanks a lot!
litouch
Re: two adsl lines' problem?Can it be done?
PPP multilink support for ATM is available which you can find in the following document. See if this is possible in your scenario. But, I guess the provider also has to support it and configure for the same. http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801149cf.html
Just ignore the policy based routing config.
Hi there, did you ended up getting this ML-PPP configuration to work?
I notice the ML-PPP was across ATM VCs and did not have CHAP authentication parameters that you would typically have for dial-up to a ADSL service provider.
79
