Two ASCII terminal talking with each other through IP NETWORK
Is it possible to connect two ASCII Terminal such;
Terminal+Router --(IP Network)-- Router+Terminal
Terminals are connnected via ASYNC Serial line.
And if so, how do you configure routers such that; Terminals can talk to each other through a TERMINAL EMULATION Program such as HYPERTERMINAL.
Silver
Re: Two ASCII terminal talking with each other through IP NETWOR
What protocol do these ascii terminal servers run? IP will work for sure. Just about anything else will have to be tunneled.
NO PROTOCOL
RAW MESSAGING
hi there,
Please take a look at the following url
http://www.cisco.com/warp/public/700/14.shtml
Alain
Hello All,
I have tried thIS Tech document but when I connect the device, telnet session gets re-intialized and data does not gets transferred. If anyboby can help me out. Please do so.
Thanks in advance and regards,
Did you run any of the debugs as suggested in the tech tip?
configure terminal
service timestamp debug date msec
end
debug modem
debug ip tcp packet N !N is the line of interest
Josh
136
